Cutting/reconnecting cable TV feed - advice needed
13 Feb 2009
Have a virgin cable feed coming into the house (bungalow), the cable feeds into the lounge where a 2 way splitter is provided to give TV and internet services.
I want to take the main cable into the loft, reconnect it to the splitter then drop the TV feed into the lounge and internet feed into the kitchen. Problem is I will need to cut the incoming cable to remove it from outside wall of the lounge and then thread it up thru thru the soffit to the loft - how do i reconnect the cut cable? do i need to buy a special crimping tool to reinstate the connector pieces? what connectors should i buy?
any advice appreciated, thanks.
Screw on "f" connectors and a back to back coupler
cheers - can i get them at a diy store? (b&q or wickes)
all of the existing connectors on view appear to be 'crimped' on very firmly, are the tools needed to do this expensive?
If you were going to do loads then get a crimp tool and the plugs..... but for a small DIY job like yours it's not really worth the cost. The screw on type will work just as well.
If you really want crimped connectors then I can make up some cable to length for you.
