hoover AM1100
7 Jun 2005
Birmingham
PLEASE HELP. my hoover washing machine does not drain the water after a full spin. Any solutions will be appreciated. thanks
In the absence of a crystal ball;
Has this only just started happening ?
How long has it worked previously ?
What has changed ? has it recently been moved ?
Does it drain on 'other' spins ? etc, etc
its been like this for a few weeks. (i've been using my mums washing machine) I've not moved it and it does not drain on any of the spin options.
Most likely the pump has failed then, but 2 options to try first;
1) check the filter on the pump is not blocked, access to this is normally through a small panel on the front lower of the machine. Pull out panel and usually 1 screw to access the filter.
2) there is a kink in the output hose from your machine to the drain pipe. not likely if you haven't moved the machine but worth pulling the machine out to check before you think about putting a new pump in.
and i was going to lend you this mate ;)
