Rad brackets, plasterboard onto lightweight thermalite wall.
5 Jul 2010
I recently have had some work in my lounge and it the builder plasterboarded over the original plaster/render onto the thermalite block wall.
As the plaster boards were dot and dabbed, in order to fix the rad brackets to the wall do I need any kind of special fixings to go through the plasterboard and plaster/render and into the blockwork behind?
I guess I would have to use quite long fixings to ensure that a lot of the body of the fixing was secure in the blockwork wall to support a lot of the weight.
Any suggestions please???
You can use the type of screws they use for PVC window fixing, you just drill a pilot hole and then screw them straight into the block, no plugs needed.
Dont try to screw straight into block without drilling the pilot first because it doesn't work.
