DIYnot
Local | Network
   DIYnot > Forums
Local | Network
wood window frame DG rebate size?
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
--tom
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jun 07, 2005 12:12 pm Reply with quote
What would be the ideal rebate size in a wood window frame for a DG unit?
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 100 times
PostPosted: Tue Jun 07, 2005 1:03 pm Reply with quote
Depending on the thickness of the DG unit, example the thickness of the glass and spacer bar.
Back to top
 Alert Moderators
--tom
from United Kingdom
Thanked: 1 time
PostPosted: Wed Jun 08, 2005 8:59 am Reply with quote
I dont know the thickness Masona, i was just wondering. The height of the rebate isn't the issue but the width of the rebate to give how much room to allow for the sealing beads?
By the way Masona, thanks for all your kind replies to my various questions.
Back to top
 Alert Moderators
biffvernon
from United Kingdom
PostPosted: Fri Jun 17, 2005 6:51 pm Reply with quote
The ideal air gap from the heat insulation point of view is about 16mm. With two sheets of 4mm glass that makes a 24mm unit. Allow 2mm either side for glazing tape and a 12mm bead to hold it all in and you find you need 40mm. In the other direction you need about 12mm to cover up the spacer and its glue. So your rebate needs to be 40mm front to back and 12mm high.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
fitting a fire door to an old frame - rebate too small 3 1920 Sun Aug 12, 2007 10:55 pm
mortice lock rebate 3 16860 Mon Oct 23, 2006 7:53 pm
Wood Door Liner/Frame 6 80 Tue Apr 02, 2013 2:58 am
Fixing Sealed Glass Unit In Wood Frame 5 1100 Wed Jun 11, 2008 6:51 am
Replace single pane in wood frame and add secondary pane 5 40 Tue May 21, 2013 5:33 pm
DIYnot
