DIYnot
Local | Network
   DIYnot > Forums
Local | Network
crabtree circuit breakers
Goto page 1, 2  Next
Author Message
mikegray
from United Kingdom
PostPosted: Tue Jun 07, 2005 3:58 pm Reply with quote
Hi
i have an old Crabtree Consumer unit fitted with type 1 circuit breakers
i need to fit a 40A or 45A breaker to it.
Can you still get type 1 breakers or equivalent from anywhere
in the 40/45A size or do any other breaker fit this CU
what would happen if i put two 32A in parrallel ??
this is only a temp fik until i have the completet thing replaced and relocated
Back to top
 Alert Moderators
mapj1
from United Kingdom
Thanked: 2 times
PostPosted: Tue Jun 07, 2005 4:06 pm Reply with quote
You should never paralell breakers - unless balancing resitors are used, which they cant be in this case, they are most unlikely to share the load equally, and will end up both tripping in rapid succesion..
Try looking here http://www.thefusecompany.co.uk/
If what you need is not on the site, then calling them can be a good starting point for looking for obscure compatible components. Not the cheapest, but good stocks
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 303 times
PostPosted: Tue Jun 07, 2005 4:21 pm Reply with quote
Its like decorating a house with a leaking roof.....
What are you installing that requires that load??
Possibly (seriously) a cheap single way CU (ebay?) henleyed from the tails would be cheaper than sourcing the MCB!
Can you take a photo of the CU and an MCB?? I have a collection of breakers - possibly the one you need icon_wink.gif
Back to top
 Alert Moderators
pdcelec
from United Kingdom
PostPosted: Tue Jun 07, 2005 4:22 pm Reply with quote
Why not fit a 1 or 2 way enclosure next to the existing consumer unit then use any of the new type mcb's
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 303 times
PostPosted: Tue Jun 07, 2005 4:25 pm Reply with quote
DP Main sw?? RCD possibly??
Back to top
 Alert Moderators
andy
from United Kingdom
Thanked: 2 times
PostPosted: Tue Jun 07, 2005 5:08 pm Reply with quote
then you have 64A. which is prob way OTT. aswell as other factors make it more dangerous
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 245 times
PostPosted: Tue Jun 07, 2005 5:34 pm Reply with quote
one possibility which should be safe enough and reasonablly practical would be to put 2 32A breakers in paralell as you suggest but then to actually protect the cable use a breaker of appropriate rating but a different brand in a seperate box near the CU.
Back to top
 Alert Moderators
Jaymack
from United Kingdom
Thanked: 3 times
PostPosted: Tue Jun 07, 2005 7:45 pm Reply with quote
Individual breakers must never be installed in parallel for whatever reason, think of the isolation dangers.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 245 times
PostPosted: Tue Jun 07, 2005 7:48 pm Reply with quote
its not something i'd do on a permanent basis no but as a temporary measure (with everyone who is working on the system knowing about it) and with appropriate protection downstream i can't see a huge issue.
Back to top
 Alert Moderators
Jaymack
from United Kingdom
Thanked: 3 times
PostPosted: Tue Jun 07, 2005 8:00 pm Reply with quote
Still against the regs. "I thought it would be all right m'lord for a short period"
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 245 times
PostPosted: Tue Jun 07, 2005 8:22 pm Reply with quote
so is leaving live wires sticking out of a switch/socket box covered with just insulation tape but i see sparkys do that all the time.
Back to top
 Alert Moderators
g-tec
from United Kingdom
PostPosted: Tue Jun 07, 2005 8:28 pm Reply with quote
if its the old crabtree C50 range they are large brown mcbs you can still get them from bemco electrical or city electrical factors
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jun 07, 2005 8:33 pm Reply with quote
Plug, I would suggest you think about that statement VERY carefully, actually think about the circuit you are suggesting and whether it would work as desired, and then think about the hazards you are introducing.
It is this type of slap dash, cowboy **** that has resulted in Part P.
Back to top
 Alert Moderators
mikegray
from United Kingdom
hi
thanks for the replys
i believe the CU is a SB6000
they are white/grey and say type 1 on them
they have a normal screw connection on the top
the supply is bussed along the bottom by a copper strip
that a screw goes through onto the breaker
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 303 times
PostPosted: Tue Jun 07, 2005 8:48 pm Reply with quote
http://www.rbstaronline.co.uk/acatalog/Crabtree_Starbreaker_range__old_type_.html
One of these - looks like they are readily available, and not to pricey.
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
wylex/crabtree circuit breakers - interchangable? 2 520 Sun Sep 20, 2009 12:54 pm
Crabtree Starbreaker - upgrade to full RCD, or RCBOs? 9 560 Sun Feb 13, 2011 8:27 pm
crabtree screwed plug 2 220 Sat Mar 05, 2011 6:24 pm
Crabtree IP56 Outdoor Socket Issues 6 280 Fri May 06, 2011 8:12 pm
New consumer unit? Hope it's not Wylex, Crabtree or Volex 37 5320 Thu Apr 01, 2010 9:25 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
