DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ideal ISAR hot water ok, but no central heating???
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
CraigBentley
from United Kingdom
PostPosted: Wed Mar 30, 2011 11:02 pm Reply with quote
A couple days ago i went to throw the heating on with no such luck. i tested my hot water worrying it was the whole boiler knackered again but that was working fine.
the wireless thermostat receiver is showing alarm, so i replaced the battery's but its still showing. following advice i pressed the override button understanding that would be the common fault an should fix the problem but again no CH. if anyone has any ideas on what else could be the problem id greatly appreciate the advice!?
Cheers Craig.
Back to top
 Alert Moderators
Gas2Air
from United Kingdom
Thanked: 96 times
PostPosted: Wed Mar 30, 2011 11:11 pm Reply with quote
It sounds like the receiver is gone. Take out batteries in the stat. Turn power off at fused spur for boiler. Wait for display to go blank in stat. Turn power back on at fuse spur. The receiver 1 should go red. Hold in 1 and 2 together. 1 will flash. Insert batteries back in stat and see if the receiver recognises it. Try that 3-4 times. Failing that link out receiver live and 3 or call and see if boiler fires.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Isar ideal he35 boiler central heating constantly running 3 980 Wed Sep 17, 2008 8:54 pm
Central heating always ON- IDEAL ISAR HE-24 4 60 Tue May 01, 2012 9:12 am
IDEAL ISAR- NO CENTRAL HEATING 10 1080 Mon Aug 20, 2007 8:33 pm
Ideal Isar M30100 - Constant Central heating? 2 80 Sat Dec 14, 2013 9:42 am
Ideal Isar HE35 no hot water or heating 2 60 Fri May 03, 2013 8:08 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
