DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Plastering internal block wall?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Author Message
bubsy83
from United Kingdom
PostPosted: Sat Apr 02, 2011 7:25 pm Reply with quote
Hi, just re-decorating the bathroom, I had to block up an old door way and the blocks I used are wider than the ones used in the house so there is about a 3/4" difference between the old doorway and the main wall, is it best to skim a scratch coat on the main wall to bring it level and then start afresh on the whole section?
Also I removed the tiles off another wall and some of the plaster came off aswell, the plaster was quite loose in alot of places so I stripped the lot off with a kango, there are alot of small raised patches of old plaster still stuck on the blocks, they are sticking out about 2-5mm, is it ok to skim over them? am I right in thinking all I have to do is wet the blockwork before applying the plaster? cheers
Back to top
 Alert Moderators
plstering
from United Kingdom
Thanked: 34 times
PostPosted: Sat Apr 02, 2011 8:11 pm Reply with quote
the wall with the door float and set it or just dot&dab the lot woth mr plasterboard or if your tiling use hardi backer board or just s/c float the lot
iv got 10 bags of bonding for sale if you want m8
Back to top
 Alert Moderators
spc
from United Kingdom
Thanked: 9 times
PostPosted: Sat Apr 02, 2011 8:15 pm Reply with quote
1: NO,dont skim straight on to block, wet or not icon_eek.gif
2: if you have a kango? take a little extra time and get the remainder of the skimming off/tile adheasive.
3: Either take a flat chistle oun the kango and take the blockwork back 10mm past the existing, tight coat of bonding, scrim joints and re skim, or dot and dab the whole wall tape and skim. the second option being quicker. Or if unlike me you can stand hollow walls see option 3 icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
plastering a block internal doorway 6 140 Wed Jul 24, 2013 7:02 pm
Plastering interior block wall 5 120 Sat Jul 07, 2012 3:18 pm
Plastering onto Breeze Block 11 260 Sun Jun 15, 2014 8:24 pm
Help! Crumbling Breeze block retaining wall 7 980 Thu Jan 21, 2010 12:03 pm
Pebbledashing/Roughcasting a new block garden wall. 7 7560 Tue Oct 02, 2007 1:54 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
