Joined: 09 Jun 2005 Posts: 10 Location: United Kingdom Thanked: 0 times
Posted: Thu Jun 09, 2005 5:38 pm Post Subject:
HELP WITH LIGHT FITTING
I have a problem, i have recently bought a bar with 3 spotlight to replace my existing light, after reading the instructions i relised that there are 3 black wires comming out of my existing fitting when the instructions indicate that thier should be only one, i dont no if this is because i have an old fitting, but i followed the instructions clearly and when i turned the power on the lights came on, but when i turned it off the fuse wire blew and i had to replace it, can anyone tell me where i am going wrong or do u need more information...Thanks
Joined: 14 Sep 2004 Posts: 3972 Location: United Kingdom Thanked: 0 times
Posted: Thu Jun 09, 2005 5:46 pm Post Subject:
Re: HELP WITH LIGHT FITTING
classic DIYers way to wire lights. u got all reds together and all blacks together? cause a direct short. you know which wire is the switch? u got a multimeter? see for reference for how it should be done properly
Joined: 27 Aug 2003 Posts: 21980 Location: London, United Kingdom Thanked: 78 times
Posted: Thu Jun 09, 2005 7:00 pm Post Subject:
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Posted: Thu Jun 09, 2005 7:20 pm Post Subject:
ban-all-sheds wrote:
but notice where i said 'you' and not 'u'! thats what counts!
actually, where is have used 'u' is where i edited the post and added more...
Posted: Thu Jun 09, 2005 7:22 pm Post Subject:
V_I_C_E wrote:
so what do you suggest that i should do now mate?
since you have the switch wire identified, head over to the reference thread and find the wiring diagrams for light fittings. re-wire your light by that
also, depending on the switch, it may need replaced due to damage from the short
Joined: 17 Jun 2004 Posts: 4538 Location: United Kingdom Thanked: 10 times
Posted: Thu Jun 09, 2005 8:18 pm Post Subject:
You need to get a piece of terminal block and use it to join all three reds together, but not to anything else. Then connect the black wire from the switch to the live (brown) connection on the light and the other two blacks to the neutral(blue) on the light. Earth wires (there should be three of them) should be covered with green and yellow earth sleeving, and connected to the earthing point on the light if one exists, if not, they need putting in a separate piece of terminal block.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
