Rads always hot.
10 Jun 2005
Could anyone please tell me why my Rads get hot at the same time as my hot water. I have the room stat turned right down and the Controller on hot water only. The valves appear to be working ok, but I'm no expert. I have a pumped system. Thanks.
Could be two known things.
The valve is not shutting off.
The system has been installed wrong and your getting a by-pass circulation through the primary circuit
because your motorized valve is letting water pass when it should be shut to heating. Needs replacing.
Thanks for the speedy replies. I've been up in the airing cupboard fiddling with the valves and have a question:
If the lever on the outside appears to moving as it should, could there still be a problem with the inner workings?
Yes the spring will be pulling the valve closed but it won't be making a tight seal for some reason and the water will pass into the heating circuit even though it's closed
Maybe this a stupid question for you, without the aid of a crystal ball....Would I change the whole valve or just the motor.
Thanks for being so helpful
your going to need to drain it down anyway so change the whole valve.
You should be able to work out from the lever if the valve is in the correct position, A, A+B or B for the required heat demand.
Its always possible that there is a control fault, perhaps the timeclock or room thermostat has failed.
If everything else is really correct then the wet part of the valve can have failed. An occasional problem is the moving rubber ball comes off the pivot or disintergrates.
Tony Glazier
Tony Glazier
I have a new timeclock and roomstat so things are pointing strongly to the valve. I'l pick up a new valve and post back later as a reference for anyone with similar probs.
Thanks again for the advice.
Could be three things now then.
Valve not closing
System not plumbed in right.
Faulty wiring to new components.
Valve not closing
Take your point. Had me thinking there for a moment, but we had this problem before the new switch and stat were installed. Also the system is plumbed in fine as it has worked correctly in the past. This will be the first time any plumbing has been altered. Ideas and thoughts always welcome.
Valve not closing
Could be 4 things, it could be the cylinder stat is faulty, but it won't be it will be the valve ;)
Wouldn't be the cylinder stat :cry: :cry:
Could be any of the other three though :eek: :eek:
I would drain out and remove the valve just to visually inspect it for I got another :idea: :idea:
An update:
I managed to salvage a honeywell valve today before a plumber skipped it. After a few choice words in the airing cupboard I replaced the motor without changing the wet part of the valve and have solved the problem.
We now have hot water, all rads are hot and cold at the appropriate times
:LOL:
Thanks all for taking time to advise.
Do you mean you changed the whole head or just the motor inside it? A dead motor would not give the symptoms you had!
