RING AND RADIAL FEED CIRCUITS
7 Jun 2003
DO YOU KNOW WHAT ARE THE DISADVANTAGES AND ADVANTAGES OF THESE TWO CIRCUITS?
yes. :evil:
radial is rarely used, because you have to use such a big cable for it, 4mm with a 30 A fuse
where as ring uses 2 x 2.5mm cables, and you can put an almost infinite number of sockets on it, it is cheaper and easier to install.
Also if you want to be really technical you can suffer from voltage drop
