Colorfill sealant or silicone sealant on joints
use both,
i personally use a poly glue and run the colorfil along the length/edge of the worktop then push them together to get the colorfil to squeeze out.
i normally use pva and silicon( coloured) but have started useung bushboards jointing compound, its the mutts nuts like, not cheap but crackin stuff
Only problem I have found with colorfil is the very short setting time. Once applied you have to tighten up the dogbones as quickly as possible. ;) ;)
never heard of the bushboards jointing compound ,where is it available from pal
