Hi ya
My client had one of these fitted
http://www.blueb.co.uk/ProductDetails.asp?Id=670
It is playing silly beggars. It'll work fine and then it starts to ignore you and either stay on or off- resulting in them needing to trip the rcd to turn it off etc
It uses IR to detect hand movements. You can hear the unit clicking (ie the relay responding) but nothing happens.
The bathroom has 7 LEDs and 2 halogens.
The suppliers swapped out the first unit for a 500w version- they explained that the higher watt version can lead to light flickering because of the capacitor and and the low draw from the LEDs.
They did a bench test prior to sending it out.
The new unit has the same issue as the other one.
The unit has since been refitted by a proper electrician. The makers suggested that the issue might be a result of the the feed and supply being reversed. I have checked and they are indeed the correct way around.
No one seems to know what the problem is.
At a guess I suspect that something might be wrong with one of the LED lights as it takes about half a second longer to light than the rest- would this be a possible issue?
At the back of my clouded mind something tells me that LED drivers can be problematic- but that might be a figment of my overactive imagination.
The original wiring was done by a "builder" who summarily snipped the earth on any circuits that end in LV/double isolation- the switch however doesn't have any kind of earth so I don't see why that would be an issue.
Any (sensible) suggestions?
Cheers
Cheers
