DVD recorder with HD
9 Apr 2005
Cleveland
Hi
I have a Daewoo HDD/DVD recorder about 2years old. Since the clocks altered it has stopped working on timed settings. Sussed out it is the date which keeps reverting to March, Works ok if I do not put it on standby.
Is it possible that it has a backup battery inside which is duff.
Thanks for reading
JonB
Could be, but more likely that it's to do with the digital switchover.
BBC2 Ceefax is where many devices picked up their time signal. That's gone a bit haywire because of prep for DSO. Try turning off Auto Update and set the clock manually. Let is know how you get on.
Hi Chris
As far as I know we up in Teesside have not been changed to digital yet.
Sept. 2012
Just checked the date again, even though it was left swiched ON all night it has reverted back to March.
This DVD player doesnt have Auto time set so I reset it every time the clocks change.
Will take the lid off & see if I can see a battery.
JonB
Just to recap, it has an Auto time set which obviously doesn't work. I have turned it OFF.
It also doen't have a battery. So will check it in a couple of hours to see if it has changed.
JonB
