DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Combi boiler diverter valve q!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
frankparkins
from United Kingdom
PostPosted: Wed Apr 13, 2011 3:15 pm Reply with quote
Hello all, I have a query I'd like help with if I may please?
A lot of newer combi's use an electric motor on their diverter valves, where the motor when energised lifts the valve to h/w mode, often when a flow turbine first senses flow and via the pcb it activates the diverter valve.
When in heating mode, does the valve stay de-energised, or does it still get energised, to ensure it is in the correct position, before allowing the heating ignition sequence?
Back to top
 Alert Moderators
jackecole
from United Kingdom
Thanked: 16 times
PostPosted: Thu Apr 14, 2011 10:02 am Reply with quote
Usually the motor only becomes activated when a hot water demand is made, by the flow switch. then the valve body inside via the motor moves and closes the heating port.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3532 times
PostPosted: Thu Apr 14, 2011 1:28 pm Reply with quote
I think you are referring to the black motors.
They are a small induction motor with three connections and two limit switches.
They run for ONLY a few seconds when either of the outer connections is made live as far as the appropriate position. When its in position the limit switch opens and disconnects the motor.
Power is continually applied to the appropriate terminal of the motor according to the current boiler function. There is no feedback so the boiler does not know if its has successfully moved.
They virtually never fail by themselves. They usually fail as a result of water leaking into them and often blow the on board fuse.
Tony
Back to top
 Alert Moderators
frankparkins
from United Kingdom
PostPosted: Thu Apr 14, 2011 1:46 pm Reply with quote
Cheers for replying guys. I have seen the black box type too, but was mainly on about the motor's such as the ones in the Vaillant ecotect range or the worcester cdi range. Just wondered how they worked in heating / hot water mode.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ideal Isar HE30 Combi Boiler - Replace Diverter Valve Head ? 24 11880 Wed Dec 21, 2011 8:08 pm
Baxi 105e combi boiler - diverter valve removal 2 100 Sat Dec 28, 2013 5:03 pm
diverter valve in a combi boiler 5 320 Mon Nov 24, 2008 8:40 pm
Replacement of Diverter Valve for a BIASI 25S combi boiler 8 1540 Sat Feb 07, 2009 2:27 pm
Worcester Bosch Combi 12/14 diverter valve 3 80 Mon Jan 20, 2014 9:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
