P.M.E. Explanation
In a PME system, the main earthing terminal of an installation is connected to the neutral of the electricity service at the consumers premises. All metallic surfaces within the building, including gas pipes, water pipes, central heating systems and accessible structural steelwork are bonded together at the consumer unit. This gives the consumer an earth of very high reliability and of low impedance. Under normal circumstances a small voltage may appear between a PME earth and the true earth potential measured outside the building as a result of voltage drop in the neutral of the electricity supply company's system. Under very rare fault conditions, such as a rupture of the neutral conductor on the supply company's system, a higher potential difference may appear which could, in theory, rise to phase-to-neutral voltage (240V). Because all the metalwork in the building is bonded together, the shock hazard is minimised because everything is at the same potential - even though this may be different from the outside earth potential.
Gees
