DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Repairing bathroom tile wall
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Author Message
tilingamateur
from United Kingdom
PostPosted: Thu Apr 14, 2011 10:56 pm Reply with quote
OK, absolute novice at anything DIY here.
Basically the bathroom tiles have come off. They have been hanging off for months now ( I don't live here full time btw). While I was back I thought I would have a go at fixing them. What I thought would be a possible an hour long job tops, appears to need more time and effort.
Took off the loose tiles and it seems the person who attached them, just used 4 blobs of cement ( or whatever ) to attach them to the wall. Even I have watched enough DIY programmes to know about needing even coverage and using the tile comb.
After pulling off the tiles, the cement/plaster underneath all started crumbling away in big chunks, very soggy like sand. I have taken all the tiles off and am letting the area dry but now I have around the top edge of the bath about 1/3 of the tile height with no plaster and just brick behind it about 2cm further back than where the rest of the tiles are stuck on.
What is the best thing to put here to stick the tiles to?
I can get you a picture if you wish.
Bear in mind I won't be the one paying for it, and I'm not looking for a huge project. It's really just the easiest way to get the tiles back on and be waterproof.
Cheers guys.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Fri Apr 15, 2011 8:23 am Reply with quote
You really posted the wrong forum, Tiling would be better. Your right in saying that dot & dab is no way to fix tiles but you have problems with both the damp & plaster failure; you cannot re-tile onto either an unsound or damp base which will take at least 4 weeks to dry out before you can do anything. If you then re-render, you will have to wait another 4 weeks (possibly 6 weeks with render that thick) before you can re-tile. Where the plaster has come off, you could pack out & fix tile backer boards to the wall level with the existing wall, assuming there is some left in good condition! I appreciate that you want a quick fix but if itís as bad as you say, whatever you do wonít last long. If itís really bad Iíd normally suggest ripping it all off, let it all dry out & start again by fixing tile backer boards.
Here is a very similar thread;
http://www.diynot.com/forums/viewtopic.php?t=270998&highlight=
Back to top
 Alert Moderators
tilingamateur
from United Kingdom
PostPosted: Fri Apr 15, 2011 11:03 am Reply with quote
Sorry, I was going to post there but I saw this one and thought it would be more suitable because of the plastering.
Thanks for your reply I will present your ideas
Back to top
 Alert Moderators
tilingamateur
from United Kingdom
PostPosted: Fri Apr 15, 2011 4:49 pm Reply with quote
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Mon Apr 18, 2011 7:35 am Reply with quote
Yes it is & I frequently use Aquapanel. Despite what it says about using timber battens, you can dot & dab into position as long as you mechanically fix through the dabs into the wall the next day after the adhesive has set, you cant just rely on the adhesive; use though frame fixings rather than screws & plugs. Itís important you fix through the adhesive dabs once dry (space on a grid approx 250-300mm) or the cement board will crack. If you mark & drill the boards first with 3mm holes, the adhesive will ooze through the holes indicating exactly where to drill through with the fixings. Stagger the vertical board joints if you can & make sure they donít coincide with tile grout lines as far as is possible.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
Filling Fake Tile Etched in Wall w/pics 5 120 Sun Oct 16, 2011 9:16 pm
Can I use BAL tile advesive cement as a wall filler? 11 1400 Tue Aug 24, 2010 1:49 pm
plastering after tile removal 6 980 Wed Jul 04, 2007 3:59 pm
plaster over tile adhesive 5 220 Mon Jan 30, 2012 9:26 pm
Time after plastering to paint/tile 3 100 Thu Mar 07, 2013 9:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
