hi all, my boiler is buzzing, it lights ok and when i start it up it stops buzzing, any ideas, all 4 of the lights work indicating no probs.
cheers
topbannana
Things which buzz most often have coils in - the gas valve, fan, relays on the printed circuit board.
The first two of those shouldn't have any power on when the boiler isn't firing. You can test that easily enough if you can drive a multimeter (and the instructions!).
The pcb is covered, but you would expect to be able to feel or hear the noise at the cover
cost about 90 suid normally pcb on ultimate very reliable double check fan and gas valve[more likely] if it is pcb make note of wiring i normally cut and leave in situ rewire one at a time
