I've bought a new Mira Sport Max 10.8kW electric shower to replace my existing mira sport shower. I'm not sure of the model or the kW but I don't think that is important.
The length of cable from the CU to the shower via a new 45A double pole switch is approx 12 meters. The 45A double pole switch will be installed on the wall outside the bathroom door due to the smallness of the room so it cannot be reached by anyone in the shower. I intend to use the existing cabling if it is 16mm. If it is only 10mm will that suffice or should I replace it with 16mm?
I'm fitting a 45A MCB (currently 30A) in the CU for the sole use of the shower circuit and installing a RCD between the CU and shower close to the CU. What size RCD should I install?
