littlecookie
Joined: 22 Apr 2005 Posts: 129 Location: Yorkshire, United Kingdom
Posted: Fri Apr 22, 2011 8:24 pm |
Hi I've recently bought the makita 3612c router and also a trend 30mm guide bush ,there is no screws with the bush ,how should the bush fit properly..thanks |
seaangler
Joined: 10 Feb 2006 Posts: 264 Location: Lancashire, United Kingdom Thanked: 15 times
Posted: Sat Apr 23, 2011 5:57 pm |
only way you can fit a trend bush to a makita is to buy a subbase - its far cheaper and more efficient to get a makita bush |
| Back to top |
littlecookie
Posted: Sun Apr 24, 2011 9:15 pm |
ok thanks il have a look for one ,just noticed the first time i used it today that the top inside sparks alot of blue sparks ....is this normal |
alumni
Joined: 12 Dec 2010 Posts: 2738 Location: Yorkshire, United Kingdom Thanked: 79 times
Posted: Sun Apr 24, 2011 10:10 pm |
| littlecookie wrote: | | ok thanks il have a look for one ,just noticed the first time i used it today that the top inside sparks alot of blue sparks ....is this normal |
Motor brushes. Just bedding in so will prob spark a tad more than normal at moment. |
| Back to top |
littlecookie
Posted: Mon Apr 25, 2011 3:55 pm |
| seaangler wrote: | | only way you can fit a trend bush to a makita is to buy a subbase - its far cheaper and more efficient to get a makita bush | .
I've noticed the makita 30mm guide bush doesnt come with any screws ,where can I get hold of them ..thanks |
seaangler
Posted: Mon Apr 25, 2011 6:49 pm |
it doesnt use screws - the base has a clip arrangement, look closely and you'll see it |
