DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Beko DWD4310 continually drains
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
alfajon
from United Kingdom
PostPosted: Mon Apr 25, 2011 8:33 pm Reply with quote
Hi, I have a BEKO DWD4310 dish washer that keeps getting stuck on drain mode. I have filled with water from a bowl and can confirm that it is not blocked as this drains ok. I have disconnected the hose from underneath and reconnected. I have also disconnected/reconnected the overflow indicator group (attached to the base) and even removed this a couple of times. This normally works for about a week before it fails again. Tried it tonight and it just got stuck on the drain. Any suggestions as its nearly as cheap to buy a new one as o get somebody else to repair. Cheers Jon
Back to top
 Alert Moderators
robbo1957
from United Kingdom
Thanked: 2 times
PostPosted: Mon Apr 25, 2011 8:48 pm Reply with quote
was there any water coming out from the base of dishwasher? if so the antiflood device is coming on, and you may have a leak also does dishwasher tend to fill up with water even when not in use? if it does then check waste pipe under the sink it has to go up above sink leval.
Back to top
The following user says thank you to robbo1957 for this useful post:
alfajon (25 Apr 2011)
 Alert Moderators
foxhole
from United Kingdom
Thanked: 886 times
PostPosted: Mon Apr 25, 2011 9:48 pm Reply with quote
I do not have the Beko but my DW has a diaphram in the sump area which detects when it is emptied by the pump [small circular black grill] this was choked with greasy scum which kept triggering the pump. Cleaned with a little hot soapy water and rinsed in boiling water from kettle and solved the problem.
Back to top
The following user says thank you to foxhole for this useful post:
 Alert Moderators
alfajon
from United Kingdom
PostPosted: Mon Apr 25, 2011 11:13 pm Reply with quote
robbo1957 wrote:
was there any water coming out from the base of dishwasher? if so the antiflood device is coming on.
Yes I think so floor is soaked accroding to the wife. Does not fill up with water when turned off. I have checked the outlet regularly. cheers Jon
Back to top
 Alert Moderators
alfajon
from United Kingdom
PostPosted: Mon Apr 25, 2011 11:15 pm Reply with quote
foxhole wrote:
.[small circular black grill] this was choked with greasy scum which kept triggering the pump. Cleaned with a little hot soapy water and rinsed in boiling water from kettle and solved the problem.
Have checked but never really cleaned the diaphram, will give a clean tomorrow.
Back to top
 Alert Moderators
robbo1957
from United Kingdom
Thanked: 2 times
PostPosted: Tue Apr 26, 2011 1:42 pm Reply with quote
the base must be clear of all water so the float on the anti flood device goes off then it should work just tip the dishwasher forward and the water will come out then try again.
Back to top
alfajon (26 Apr 2011)
 Alert Moderators
alfajon
from United Kingdom
PostPosted: Sat May 21, 2011 9:11 am Reply with quote
Ok, so it is definately the antiflood device working. Any idea's why and how to rectify?
Back to top
 Alert Moderators
Leccy758
from United Kingdom
Thanked: 196 times
PostPosted: Sun May 22, 2011 5:37 pm Reply with quote
You got to find the leak, not always the easiest to do.
Remove the sides and look inside the base, check around the circulation pump and seal for crusty looking deposits, see if there is an obvious start point to the staining in the base.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Bosch f/freezer continually ices up 8 1040 Tue May 09, 2006 10:27 am
Indesit W133 Programmer Continually Rotates Light flashes 3 1400 Sat Mar 31, 2007 8:41 am
dishwasher runs 2/3 of its cycle, and pumps out continually 2 300 Mon Aug 11, 2008 8:49 pm
Bosch - Drains and then backfills 5 3420 Mon Sep 11, 2006 10:43 am
Maytag only spins and drains in Delicate Cycle 2 2160 Fri Oct 06, 2006 1:05 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
