| Author |
Message |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 41392 Location: London, United Kingdom Thanked: 1337 times
Posted: Tue Jun 14, 2005 9:41 pm |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
andy
Joined: 14 Sep 2004 Posts: 3971 Location: United Kingdom Thanked: 2 times
Posted: Wed Jun 15, 2005 4:00 pm |
| Back to top |
HDRW
Joined: 28 Feb 2005 Posts: 296 Location: Hertfordshire, United Kingdom Thanked: 3 times
Posted: Thu Jun 16, 2005 5:23 pm |
Hmm... £999.95... I wonder if he'd do it for £999.00 for cash?
I love the assertion: "HAVING A GENERATOR CHANGE OVER SWITCH MEANS YOU'LL NEVER HAVE THESE PROBLEMS AGAIN. YOU'LL ALWAYS HAVE ELECTRICITY." - there is the minor point that you need a generator too...
Given that a generator is a "special installation", I wonder if they're Part P registered?
Cheers,
Howard |
| Back to top |
ban-all-sheds
Posted: Thu Jun 16, 2005 5:34 pm |
| HDRW wrote: | | Given that a generator is a "special installation", I wonder if they're Part P registered? |
WGAS?  |
| Back to top |
andy
Posted: Thu Jun 16, 2005 6:28 pm |
| ban-all-sheds wrote: |
63 A Generator Change Over,
100A Connector Block,
32A Connection Socket,
A connection lead from generator to the socket. |
so, people, how much would all this cost? apparantly the changeover switch is *really* expensive |
| Back to top |
Big_Spark
Joined: 20 Feb 2004 Posts: 3434 Location: United Kingdom
Posted: Thu Jun 16, 2005 7:16 pm |
Chang-over switches CAN be expensive, but not that long ago I had cause to replace an Autochange-over Contactor in a building, that unit was rated at 600A and as it's name implies, was automatic, it cost £435.98 + VAT from a wholesaler.
A Manual unit, as they imply, would cost about £140 plus vat...so they are overcharging.. |
| Back to top |
andy
Posted: Thu Jun 16, 2005 7:30 pm |
| FWL_Engineer wrote: | Chang-over switches CAN be expensive, but not that long ago I had cause to replace an Autochange-over Contactor in a building, that unit was rated at 600A and as it's name implies, was automatic, it cost £435.98 + VAT from a wholesaler.
A Manual unit, as they imply, would cost about £140 plus vat...so they are overcharging.. | so were lookin at £200 parts. so thats £800 fitting. not bad for a days work. i should start and sell them |
| Back to top |
ban-all-sheds
Posted: Thu Jun 16, 2005 8:09 pm |
| FWL_Engineer wrote: | | A Manual unit, as they imply, would cost about £140 plus vat...so they are overcharging.. |
£140? Even TLC only charge £65 for a 63A 3-pole changeover....
Having thought about where it goes, a 63A one probably wouldn't do - 80/100A would be needed, so this would be more..
Last edited by ban-all-sheds on Fri Jun 17, 2005 6:43 pm, edited 1 time in total |
| Back to top |
andy
Posted: Thu Jun 16, 2005 8:12 pm |
£140? Even TLC only charge £65 for a 63A 3-pole changeover.... |
oh, but this is an expensive type!
| Quote: | | The cost of the actual change over switch is the expensive part. It's not just a switch it has to switch heavy loads. Where abouts in the uk are you? |
| Back to top |
andy
Posted: Fri Jun 17, 2005 4:01 pm |
| seller of gen kit wrote: | We are fully registered. The cost of the actual change over switch is the expensive part. It's not just a switch it has to switch heavy loads.
The Generator Change Over Switches measures approx 25cmx25cm it needs to be installed where your regional electricity suppliers cable comes in which is where your fuse board probably is. It is connected in between your meter and consumer unit/ fuse board so that when you are using generator power it does not through your meter so your not charged for it. We allow a day for installation but it should be a bit quicker it always depends on the location of the fuse board. |
a day to install... must be bloody hard work! |
| Back to top |
ban-all-sheds
Posted: Fri Jun 17, 2005 6:38 pm |
I wonder if they pull the fuse, or get the DNO out...
I guess anybody planning a DIY install of an isolation switch could do a c/o just in case they ever buy a genny.
A thought which occurs to me - how are generators earthed?
Last edited by ban-all-sheds on Fri Jun 17, 2005 6:45 pm, edited 1 time in total |
| Back to top |
andy
Posted: Fri Jun 17, 2005 6:44 pm |
| ban-all-sheds wrote: | | I wonder if they pull the fuse, or get the DNO out... |
well soon find out....
EDIT: response from them about the service fuse
| Quote: | Hi Andrew we have installed many of these Generator Change over Switches you do not need the regional electricity supplier to come. We can carry out any re-crimping that is required.
Thanks Paul. |
whats the legality of them pulling the fuse and re-sealing it? |
| Back to top |
Spark123
Joined: 02 Jun 2005 Posts: 13741 Location: Cumbria, United Kingdom Thanked: 338 times
Posted: Fri Jun 17, 2005 7:53 pm |
A thought which occurs to me - how are generators earthed? |
My generator has a plug with a linked neutral to earth and is connected to an earth electrode, supplying through an RCD. This is how I was told to do it by the generator manufacturer. |
| Back to top |
andy
Posted: Fri Jun 17, 2005 7:54 pm |
| Spark123 wrote: | | ban-all-sheds wrote: |
thats what i would have thought. plus a changeover switch.
little more complicated if you want it to auto start etc, but all he's selling is a manual type |
| Back to top |
ban-all-sheds
Posted: Fri Jun 17, 2005 8:47 pm |
I'm sure those small portable generators don't have an earth rod...
But in any event - if you connect them into your installation with a changeover switch, where do you put the generator earth, and what about your supply earth? |
| Back to top |
