DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Waterproofing plaster wall behind shower tiles
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
DH05
from United Kingdom
PostPosted: Wed Jun 15, 2005 7:24 am Reply with quote
I read somewhere that it's a good idea to waterproof plaster walls before tiling a shower or bath, particularly at the bath edge where someday the caulking and grout may deteriorate and let water in. The wall in question is plastered with "bonding" which is very very absorbent of water.
Local shops claim there is no such product and that it is unnecessary.
Advice?
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Wed Jun 15, 2005 6:56 pm Reply with quote
Most tilers I have seen just give the wall a coat of pva..this is just to aid adhesion though by stopping the adhesive soaking into the wall to quickly.
You could always give the wall a couple of coats of plaster primer or alkali resiting primer....it certainly wouldnt do any harm.
Back to top
The following user says thank you to Zampa for this useful post:
Robbie uk (12 Jul 2014)
 Alert Moderators
tylerb
from United Kingdom
PostPosted: Thu Jun 16, 2005 7:07 am Reply with quote
There is such a product. It is known by the professional tiler (not those who claim to be a tiler) as a tanking system.
Grout will let water pass through and damage the plaster behind.
The tanking stops this by forming a water proof membrane between the tile and the plaster.
Most adhesive manufacturers make one.
You can call PITT technical or BAL technical if you wanted to ask them if what I am saying is true.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Thu Jun 16, 2005 1:20 pm Reply with quote
Spot on, no grout is 100% waterproof even swimming pool !
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Fri Jun 17, 2005 10:22 pm Reply with quote
I never knew that.......always asumed that when a grout says 'waterproof' it means it.....it obviously doesnt make the tiles competely fall off otherwise tere wouldnt be a swimming pool left......but can it do a lot of damage?
Back to top
 Alert Moderators
tylerb
from United Kingdom
PostPosted: Mon Jun 20, 2005 7:03 am Reply with quote
A swimming pool is tanked in its own right. Grout and adhesive is not wateproof but can be water resistant therfore the tiles wont fall off in the swimming pool. This is what people dont understand and this is why there are so many problems in peoples showers at home.
Ty
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Mon Jun 20, 2005 6:12 pm Reply with quote
Ty
On the strength of that then.....would that mean a wall would be soaked after every shower?......got me worried now about my own tiling efforts.. icon_confused.gif
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Mon Jun 20, 2005 7:32 pm Reply with quote
Normally the tiles from the bottom 1/3 up because where it most likely to be wet. Mostly the problem is with plasterboard even with pva sealant and depend how often the shower is being used. You can always tell when it's happening by tapping the tiles for the echo sound effect and black mould on the plasterboard. When I did mine I knock the old tiles off and put in plastic shower panel wall instead for trouble free maintenence, so I wouldn't worry too much about it as there're ways round it such as Aqualpanel or shower panel etc. In swimming pool the tiles behind is wet and only for decorative purpose.
Back to top
 Alert Moderators
tylerb
from United Kingdom
PostPosted: Tue Jun 21, 2005 7:37 am Reply with quote
It takes 45 seconds for water to soak the back of a tile in a standard domestic shower by passing through the grout. Sorry to get so technical but this is how tiling has got to be. There are to many tiles falling off walls at the moment and causing serious injuries. Just been to a job where a 7 and 5 year old were injured through marble tiles falling off. People should not attempt tiling unless they have undertaken some form of training, even if it is only a short burst course.
Back to top
 Alert Moderators
waynes
from United Kingdom
PostPosted: Wed Aug 10, 2005 12:59 pm Reply with quote
I may have missed the answer here but ill ask anyway..
so if the grout allows the water through what would you suggest be done to the plasterboard before the tiles go on?
and where are we likely to find such a product? just before I start tiling next week....
Back to top
 Alert Moderators
tylerb
from United Kingdom
PostPosted: Thu Aug 11, 2005 6:55 am Reply with quote
If you have a look at www.tileforums.com they talk about a tanking system. This is a water proof membrane that you apply to the plaster before tiling. On the forum they will tell you how to do it.
Back to top
 Alert Moderators
stevedo
from United Kingdom
PostPosted: Thu Aug 11, 2005 7:11 am Reply with quote
So if the grout lets water through so quickly, why not put a thin "slither" of bath and shower sealant in the gap between the tile and top up with grout for that perfect aesthetic look.
Back to top
 Alert Moderators
tylerb
from United Kingdom
PostPosted: Thu Aug 11, 2005 8:03 pm Reply with quote
because i know what i am doing. Tanking a shower will only take 15 minutes to do. How long will it take to fill each grout joint with a sealant that will never truly bond to the tile anyway?
Back to top
 Alert Moderators
evanjones
from United Kingdom
PostPosted: Fri Jul 11, 2014 1:28 pm Reply with quote
Sorry to drag up a very old topic...
Is there any need/benefit to "tank" if my walls are real plaster, not plasterboard??
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
waterproofing before tiling in shower 2 620 Mon Feb 18, 2008 5:11 pm
Waterproofing grout - Can it be done? 3 620 Fri Oct 28, 2005 2:52 pm
Internal wood waterproofing 5 200 Fri Mar 18, 2011 10:02 pm
Waterproofing wallpaper 8 8440 Sun Apr 02, 2006 11:24 pm
Coloured grout for shower tiles 6 1000 Thu Apr 26, 2007 1:52 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
