DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting Washing Mach.
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
smithsyard
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 15, 2005 8:44 am    Post Subject:
Reply with quote Thanks
Am fixing up a new washing machine. I have switched off the mains - no cold water which is good and switched hot water taps on to drain the residual hot water in the pipes - the flow does not stop though (was on for hours). Any ideas???
It is a combi boiler.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
nstreet
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 15, 2005 8:47 am    Post Subject:
Where did you turn off the mains. You may have more than one stop cock. Each of our cold pipes has it own stopcock!. Try turning it off outside at the meter, if you have one or the main property stop cock.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Wed Jun 15, 2005 8:49 am    Post Subject:
there should be an isolater under the boiler on the cold feed in
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
smithsyard
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 15, 2005 8:52 am    Post Subject:
It's only a small 1 bed flat....if i turn off water outside will that not effect the other 7 flats?
Back to top
 Alert Moderators
nstreet
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 15, 2005 8:58 am    Post Subject:
Look for the isolator as KevPlumb suggests then.
Back to top
 Alert Moderators
smithsyard
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 15, 2005 8:59 am    Post Subject:
Thanks - clearly not up on this plumbing game - what does an isolator look like?
Back to top
 Alert Moderators
kevplumb
Thanked: 400 times
PostPosted: Wed Jun 15, 2005 9:07 am    Post Subject:
silver valve on the cold water pipe inti the boiler
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
filling of cold water to washing/mach 3 2180 Thu Aug 16, 2007 12:54 pm
washing machine waste problems 11 500 Tue Jun 20, 2006 9:19 am
run pipes through garage for plumbing in washing machine 4 580 Mon Jun 19, 2006 12:31 pm
Splitting supply to plumb washing machine in 9 320 Wed Jun 07, 2006 3:05 pm
washing machine drainage 10 2580 Thu Jun 01, 2006 5:07 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
