I have just had the above cooker delivered & need to install it.
Simple question is what cable to use. The back connection plate & cooker switch are all there but just need to connect the cable from cooker to back plate.
I will turn all the power off whilst installing it.
Voltage & frequency of cooker is 230-240v - 50Hz if that helps.
The cable in the back plate which i need to connect to is quite big & each wire (live,neatral & earth) contain 7 wires within each sleeve.
Do I use the same size cable as this ?
Thanks for your help.
