Hi I have a problem with my hotpoint wf540 washing machine: Under a normal wash (f) the machine stopped working and the door locked led started flashing with the wash led on solid.
Turning the machine off then on after ten minutes and pushing the start/cancel button all that happens are all the leds light up apart from the door lock for 5 or so seconds they then go out, the wash led comes on solid a click is heard and a very very small amount of water is pumped at the soap tray. After this nothing then 10mins or so the door lock led starts flashing.
Things I have looked at so far include the door switch seems to be working as it will lock and not open, cleaned the plug and connectors. Removed the motor and checked the brushes which are worn but still look like they have another 5-10ml left is this not enough? Cleaned out the filter in the front lower right hand corner and checked the impeller is spinning free with no blockages.
Thanks in advance for any help
Johnny
Johnny
