DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Brick Pillars
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
GazSuttonUK
from United Kingdom
PostPosted: Thu May 05, 2011 3:45 pm Reply with quote
Im going to build two brick pillars at the end of my drive approx 4' high, do I fill the void in the pillar with concrete/hardcore?
Cheers.
Back to top
 Alert Moderators
theoldun
from United Kingdom
Thanked: 321 times
PostPosted: Thu May 05, 2011 4:24 pm Reply with quote
As you are talking about filling in the centre void, your piers must be going to be 327mm square or bigger.
If no gates are being hung then brick the void up with brickwork as you come up.
If hanging gates put cranked RE bar in founds finished 100mm lower than top of pier and fill void with concrete
Do not put poly DPC in. If you want a DPC use two course Staff Blues
oldun
Back to top
The following user says thank you to theoldun for this useful post:
GazSuttonUK (5 May 2011)
 Alert Moderators
GazSuttonUK
from United Kingdom
PostPosted: Thu May 05, 2011 7:22 pm Reply with quote
Yes the centre void.
Ive just measured and the void will be 8" x 8", the pillars will be standalone with no gates fitted..
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
PostPosted: Thu May 05, 2011 8:49 pm Reply with quote
If you are having one of those poxy concrete coping stones, then the centre can be left hollow. If you are having a proper brick on edge or similar then the centre needs to be solid
The simplest thing is to just lay the two bricks in the centre every course.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1293 times
PostPosted: Fri May 06, 2011 4:20 pm Reply with quote
I agree with Old codger on this one regards strength.
We shove in some lengths of rebar into the wet footing concrete then brick up around the bars.
Then fill with wet conker the next day.
If it is simply a wall pillar then drop a couple of bricks in the centre. Make sure that the infill bricks are at least a course behind the outer decor bricks to avoid any push.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Brick Pillars 2 80 Wed Jun 19, 2013 7:34 pm
Pillars and brick walls 3 200 Fri Sep 26, 2014 8:12 am
Steel pillars instead of engineering brick pier 13 280 Tue Sep 17, 2013 7:16 am
Building open porch but should I go with brick pillars? 3 1020 Thu May 12, 2011 11:40 am
Pebbledashing pillars 5 600 Sun Apr 16, 2006 10:27 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
