Hi
I'm new to the forum and seeking advice.
I had an issue tonight of a short circuit on a 'kettle' type lead (the type with a clover leaf shape connecting a laptop psu).
The Mrs shouted up in a panic that something was burning, I rush downstairs and we find the cable smoking away, she lifted the psu off the carpet and there was a couple of flashes and popping etc and I turned it off at the wall, the whole episode lasted maybe about 30 seconds.
The cable nearest the clover leaf end had split open and shorted out and melted, the neutral cable seems to have melted away, the earth is exposed and it looks like the live was not shorted but unsure. I'm guessing that the cable was initially damaged by the sofa as it's an electrical reciner type and quite possibly trapped the cable between it and the floor a few times.
I checked the fuse in the plug, 13A and did not blow, neither did the ring main MCB. The socket it's plugged into is no more than about a couple of metres away from the consumer unit.
The wiring and consumer unit is approx 12 years old now as I rewired it when we moved in, seperate ring mains for upstairs and downstairs on their own MCB's. I did qualify as a sparks 15-20 years ago but didnt contunue past the apprenticeship as I changed trades to a slightly different field, so am not up to date on the regs and rusty on the theory side of things, but consider myself competent enough for DIY still.
So my question is: Why no trip? Ok the 13A fuse was too high for the device - will get a load of 5a's tomorrow and check all my computer kit etc and change them all. Should not the MCB have tripped or would it have taken longer? I'm quite concerned it was crackling away and not tripping anything. I'm wondering if it was only the earth and neutral shorting out but would that have caused the fireworks? Maybe the PSU itself added to the problem if developing a fault?
Any advice appreciated, will open up the socket tommorow and double check connections and voltages, but getting a bit concerned.
Cheers
Rich
Cheers
Rich
