DIYnot
Local | Network
   DIYnot > Forums
Local | Network
replacement for potterton ep2002 programmer
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
victor71
from United Kingdom
PostPosted: Mon May 09, 2011 9:17 am Reply with quote
Hi everyone,
The central heating in my house is not working bcos of faulty programmer potterton ep2002. I have tried to find like for like replacement but it is out of stock everywhere, perhaps manufacturers stoppped the production of EP series as they are out of stock since january. Can anybody help me if there is any other programmer to replace with without changing any wiring arrangements. Thanks in advance.
Back to top
 Alert Moderators
45yearsagasman
from United Kingdom
Thanked: 873 times
PostPosted: Mon May 09, 2011 9:55 am Reply with quote
Potterton EP 6002 is a straight swap. How do you know its the programmer at fault?
Back to top
 Alert Moderators
victor71
from United Kingdom
PostPosted: Mon May 09, 2011 10:04 am Reply with quote
i checked it with a multimeter, hot water is working fine. its the relay gone on ch.
Back to top
 Alert Moderators
45yearsagasman
from United Kingdom
Thanked: 873 times
PostPosted: Mon May 09, 2011 11:40 am Reply with quote
OK, just replace with the EP 6002.
Back to top
 Alert Moderators
victor71
from United Kingdom
PostPosted: Mon May 09, 2011 2:34 pm Reply with quote
Potterton EP series not available anywhere at moment, i am looking to replace it with a different programmer than potterton. Thanks,
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Mon May 09, 2011 6:37 pm Reply with quote
Don't replace it with another ep, they are pants, get a Honeywell, Drayton or Danfoss.
Back to top
 Alert Moderators
victor71
from United Kingdom
PostPosted: Mon May 09, 2011 7:10 pm Reply with quote
bengasman, i am looking for the easy wiring option which i can do myself if i change it to different make programmer. Any advice please which programmer and wat to do with the wiring.
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Mon May 09, 2011 7:19 pm Reply with quote
Wiring is really simple for anyone who is au fait with working on 230V.
Probably best to start with getting the correct diagram for the system you have, and check that all is wired up as should be.
Between the wiring diagram e.g. s-plan and the diagram that comes with the timer, it's a piece of urine.
Forgot to mention: make sure you get an independent model; this day and age there is no reason for running dhw and ch at the same time, unless you have a small cylinder and extreme dhw usage.
Back to top
The following user says thank you to bengasman for this useful post:
victor71 (10 May 2011)
 Alert Moderators
45yearsagasman
from United Kingdom
Thanked: 873 times
PostPosted: Tue May 10, 2011 7:39 am Reply with quote
I did not realise ep's were not available (never used them because of poor reliability)
Any programmer replacement will require a rewire as the backplate is unique
and they were often used as a wiring centre.
Back to top
The following user says thank you to 45yearsagasman for this useful post:
 Alert Moderators
misterdubya
from United Kingdom
Thanked: 368 times
PostPosted: Tue May 10, 2011 9:07 am Reply with quote
I know you dont want another one, but they are still available HERE
Mr. W.
Back to top
 Alert Moderators
victor71
from United Kingdom
PostPosted: Tue May 10, 2011 12:24 pm Reply with quote
misterdubya,
i still want to buy it bcos its easy for me to replace but they are not available. If u stock check on that site it will tell u ''out of stock''. thanks anyway.
Back to top
 Alert Moderators
mickyg
from United Kingdom
Thanked: 3218 times
PostPosted: Tue May 10, 2011 1:50 pm Reply with quote
Flip it off the wall and check the wiring to see if its been used as a wiring centre. If its only been run in with the programmer wires should be very straight forward to rewire and replacement. I use Danfoss 715, but honeywell and drayton are also good.
Back to top
 Alert Moderators
Whitespirit66
from United Kingdom
Thanked: 606 times
PostPosted: Tue May 10, 2011 2:24 pm Reply with quote
victor71 wrote:
misterdubya,
He's right. Who's buying all these $hite programmers? Just put an EP6002 on the existing backplate. No wiring changes, and you can have seperately timed HW and CH.
Or, EP2002 available on Ebay
http://cgi.ebay.co.uk/Potterton-ep2002-7-day-timer-/230619370636?pt=UK_Home_Garden_Hearing_Cooling_Air&hash=item35b1fc548c
Back to top
 Alert Moderators
JamesBlonde
from United Kingdom
Thanked: 1 time
PostPosted: Mon Dec 12, 2011 9:50 pm Reply with quote
Long shot, and only 6 months late, but if you're still looking, the EP6002 is in stock at www.discountheating.co.uk - just got one delivered. Had the same problem as you in the summer trying to get hold of one, although my EP2002 still worked luckily.
Back to top
 Alert Moderators
darenfriday
from United Kingdom
PostPosted: Sun Aug 05, 2012 6:14 pm Reply with quote
I have an EP3002.
What were the symptons of your faulty CH. Everytime the heating times on it fires constantly regardless of the wall room stat.
Does that sound familiar?
Daren
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Help-purchase a slide switch for Potterton EP2002 programmer 3 660 Tue Nov 11, 2008 3:26 pm
help needed-fuelsaver mk2 boiler+potterton ep2002 programmer 3 1000 Fri Mar 09, 2007 2:58 am
Potterton EP2002 Programmer 2 780 Tue Nov 06, 2007 9:28 am
Potterton EP2002 programmer problem? 3 780 Sat Dec 04, 2010 4:07 pm
Heating but no hot water - new programmer EP2002? 3 300 Mon Dec 21, 2009 7:50 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
