DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester Greenstar 28i Junior
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
en7gjh
from United Kingdom
PostPosted: Wed May 11, 2011 11:33 am Reply with quote
Hello all.
My 28i junior has scale in the heat excahnger due to the hard water here in berkshire, hot water pressure is now at a dribble. A couple of weeks ago I fitted an electronic descaler and this appears to have made things worse - is it scale comin goff inside teh system and getting clogged in the heat exchanger? The kettle now gets a lot less scale, barely any.
I have been advised to change teh heat excahnegr outright, but am contemplating either paying to flush teh system, or take out the heat excahnger and get it cleaned out.
The boiler has two heat exchangers, primary and secondary, whcih one needs cleaning?
I would be grateful for any advice.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3438 times
PostPosted: Wed May 11, 2011 11:51 am Reply with quote
In your case the secondary heat exchanger domestic water side which needs cleaning.
Even in your area its rare for the plate HE to get scaled up if there is no other problem.
Are you sure you have not had some dripping taps or a leaking washing machine valve?
Tony
Back to top
 Alert Moderators
en7gjh
from United Kingdom
PostPosted: Wed May 11, 2011 11:57 am Reply with quote
So should i clean it or replace it as advised? How would dripping taps impact on the water pressure, from 10bar to a dribble?
Is it easy enough for a DIYer to take out the secondary HE and clean it with descaler?
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1030 times
PostPosted: Wed May 11, 2011 1:39 pm Reply with quote
Forget the secondary heat exchanger for the moment.
Remove the DHW flow sensor assembly and check the inlet filter and the flow limiter.
Back to top
 Alert Moderators
en7gjh
from United Kingdom
PostPosted: Wed May 11, 2011 3:43 pm Reply with quote
okay, will give it a go. Is the secondary HE for the DHW and the primary the CH?
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1030 times
PostPosted: Wed May 11, 2011 4:06 pm Reply with quote
The secondary heat exchanger exchanges heat energy from primary heat exchanger to the domestic water. The primary water is also used for the radiator circuit.
FORGET the heat exchanger at this stage...check the filter/flow limiter FIRST.
Back to top
 Alert Moderators
en7gjh
from United Kingdom
PostPosted: Wed May 11, 2011 6:31 pm Reply with quote
Okay,
I assume I isolate the stop cock, drain the DHW, isolate the gas (precaution?) then take off the various bits.
Do you recommend new seals/o-rings?
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Wed May 11, 2011 7:34 pm Reply with quote
edit
Back to top
 Alert Moderators
en7gjh
from United Kingdom
PostPosted: Thu May 12, 2011 9:51 am Reply with quote
Not managed to take off the flow sensor yet, but have tomorrow set aside to sort out the problem.
The water pressure is still low, although it has now turned cold. As an experiment I put the heating on last night and it worked perfectly fine, the whole system was hot within 10/15 minutes.
Would anyone suggest ordering in a secondary heat exchanger just in case?
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1030 times
PostPosted: Thu May 12, 2011 6:58 pm Reply with quote
No icon_rolleyes.gif Sort out the basics first. The flow limter assembly will contain an O ring...chuck it and see if the flowrate improves.
Back to top
 Alert Moderators
en7gjh
from United Kingdom
PostPosted: Fri May 13, 2011 12:00 pm Reply with quote
I have taken out the flow sensor and the 'filter dcw', both are completely clear. Not sure what you mean by the 'o-ring' but if you are refering to the 'flow limiter insert 10lt' I didn't take this out.
Do I consider the heat exchanger at this stage?
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1030 times
PostPosted: Fri May 13, 2011 3:03 pm Reply with quote
Yes icon_smile.gif this is the flow limiter...they can also block but a common fault is the degradation of the O ring. They can become contaminated and cause a partial blockage. The flow limiters are fitted to stop dumb customers phoning up complaining of poor hot water temperature if there is too much flow.
I suggest you remove the O ring inside the flow limiter to rule this potential problem out.
Back to top
 Alert Moderators
Butchybutch
from United Kingdom
Thanked: 25 times
PostPosted: Fri May 13, 2011 7:46 pm Reply with quote
Think carefully before attemping to remove the plate heat exchanger, its not as easy as you might think,
If you end up removing the hydraulic block buy some new washers for the primary pipe connections with the white twist fasteners, you also might want to change the PRV at the same time.
Back to top
 Alert Moderators
en7gjh
from United Kingdom
PostPosted: Sat May 14, 2011 2:41 pm Reply with quote
It was the secondary heat exchanger!
It was difficult to remove (for the plumber) as the original plumber who fitted the boiler 3 years ago left insufficient clearance below the boiler (only 100mm, not 200mm).
Thanks all.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
worcester bosch greenstar 24i junior DHW problem 5 1460 Fri Apr 02, 2010 6:22 pm
worcester bosch greenstar 24i junior pressure problem 4 9900 Tue Apr 17, 2007 6:04 am
Repressure worcester greenstar 28i junior 2 60 Thu Nov 01, 2012 1:31 pm
How to remove thecover from a worcester greenstar 28i junior 11 3200 Fri Sep 28, 2012 7:47 am
Worcester Greenstar 28i Junior - no hot water 7 1060 Wed Nov 23, 2011 9:12 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
