Hi Im about to tile a shower wall .. I have used Aqua board from Wicks, The adhesive I have is Bal Ctf3 do I need to use an additive? I will also do some tiling in the dry area of the bathroom but only as a splashback same question. The tiles are ceramic 500x250. lastly I have set out the tiles horizontally and the boarder is 40mmx 500 Passes through the center of the shower valve and the joint is also in-line with the windowsill so should look good, and help with cutting out the correct shape for the valve as it can be from 2 tiles .. the only problem is I have a small cut tile at the ceiling height 20mm ish will this look silly? the shower cubical is 1200w x 800d. thanks
