Underfloor heating problem
15 Jan 2011
West Lothian
I have an underfloor heating system in my house on both the ground floor and the first floor. The ground floor manifold operates fine but I have a problem with the first floor manifold. If the heating is on downstairs but off upstairs then the return gauge on the upstairs manifold goes up to 60 degrees C and the flow gauge reads 40 degrees C, if the upstairs comes on whilst the ground floor is on then the return gauge drops to 40 degrees C and both the flow and return gauges continue to read 40 degrees C even after an hour.
Any ideas?
Thanks.
I am not sure there is anything wrong yet.
Is this a new situation?
Both at 40 C indicates a very high flow rate and the pipes up to temperature. Not necessarily wrong.
But we need further details of your system! Does it have a circulating pump on each manifold?
Tony
May sound silly, but check that the pumps are both installed the right way, and that they pump from the same flow pipe. Saw one a couple of months ago where the upstairs circuit drew from the flow pipe, but the downstairs one from the return. It had been like that for 6 years.
Ok I'll check that out. Would I just disconnect the flow and return from the boiler at the manifold and see which one has water coming out from it?
You need to be able to follow the pipework from the boiler or thermal store. How far apart are the Manifolds. There will be a directional arrow on the pump body.
