Drainage pipe leaking
3 Mar 2010
Hampshire
Hi All,
I had to remove the drainage pipe from my washing machine in order to get hold of a sock which was preventing the drum to spin properly. Now the drainage pipe is leaking slightly from the clamp when the pump is pumping water out. I tried to tight it a lot, a bit and nothing seems to work. I cleaned the edge and I checked the rubber and everything seems to be OK. Is there any sealant or something I can use to stop this leak?
Have you used a jubilee clip they are normally better than the clips that hold it on.
Yes, I am using the jubilee clip which was originally on. I suspect the pipe is somehow distorted or something. I do not want to change the pipe unless I have tried other alternatives first
No I have not although I thought about it. I just though ptfe tape was meant to be used for threads only and the outlet of the washing machine is not.
Is there threads on the pump there normally is.
I assume you mean the rubber piece on the end of the waste pipe where it fits over the spigot on the pump is leaking?
Check the pipe is fully over the spigot and the clamp is fully down and not just catching the end of the spigot.
If you mean the sump hose then it can be a pain to seat it correctly on some machines, keep checking it is fully on all the way round before clamping and that it does not move when you tighten the clamp
Yes I meant the sump hose. Sorry If I have not describe it properly. It is really a pain to adjust it back as you say. I assume I will have to keep trying to fit it as you say making sure the hole hose is attached to the spigot. Would a bit of silicone around the spigot help?
