Hey all,
I've look all over the net and am not able to find an answer to this question, i've searched this sites post and found similar question, but with no resolution.
I recently had a new combi boiler installed which means the washing machine was moved to get access to pipes. After the machine was returned to it's location the machine stops mid cycle with a flashing Active light,and the door is openable after a short while.
I did all the troubleshooting methods found in the manual i.e. checking the hoses were alright/water turned on/and checking the strainer of which a bra wire was found. cleaned the strainer and tried again, same problem.
I set it to drain to see if anything would work and now the above still happens but only on a 60c wash or above, no water comes in to the machine at all on on a 30/40c wash setting.
Any help most appreciated
Ta
nilan01
Ta
nilan01
