Hot water only for 20 seconds
22 Jun 2005
Kent
Have a Biasi Prisma S 28SE boiler.
Have set the boiler to the winter setting (which allows it to only come on when the hot tap is turned), working fine for the last two months - But now when I turn on the hot tap sometimes the pilot light comes on for 20 seconds and turns off, other times it never comes on. So I get no hot water.
I set the boiler back to winter, again it continues as above.
Any ideas?
Thanks for your help :eek:
thanks for the quick response, could you just claify where and what I'm looking for
Thanks!
Thanks - Don't suppose you have a user manual?
Also when the bolier is switched off from the mains, should the nobs for the winter/summer water/central heating being on a particular setting?
Thanks for all your help
Thanks for all your help yesterday, when I got home i tried the boiler and it started working!! Totally bonkers,
