Had dificulty replacing an existing Mira shower, finally selected a Newteam model that has given good service over the years. The model was selected as it had the flexiblity of water entry to match the existing pipework. Recently removed the unit to retile then refiting had leaks when fiting the push fit type connector back to the supply pipe. Does the following item exist, a fexible hose with compression fiting each end to make a proper connection, flexible due to the pipe entry angle and the space within the shower moulding.
