Gate across shared pathway
14 Sep 2009
Manchester
We are presently house hunting and one of the properties we are interested in is a semi-detached which shares access to the front of the house (footpath only) with the adjoining property – i.e. a single path skirts the front walls of each property and divides each house from its front garden. As we would own the first property, all access to the front of our neighbour’s house would be via our front garden. There is separate access to the properties from driveways at the rear.
For the sake of the children’s safety we would ideally like to put a gate across the entry due to its proximity to the roadside. This would be a simple wicket gate with some form of latch (it would not need locking as we are simply trying to keep the children from spontaneously running out into the road when chasing balls etc).
Is it a simple matter of agreeing the provision of a gate with the neighbours (we would meet the full cost) or is some kind of planning permission likely to be needed? As far as I am aware both properties are freehold but I am not familiar with the regulations governing access to one building via another person’s property. Providing we can agree this with the neighbours (and I see no particular obstacle in that direction) would the agreement be permanent or could this be rescinded if the neighbouring property was to be sold?
Any advice welcome. Thanks.
The arrangements for access will be determined by the properties' deeds.
They are unlikely to specify whether a gate is or is not allowed or prohibited.
Planning permission unlikely to apply unless the gate is more than 6' high on a boundary.
If the access path is on a specific property, then normally the property owner owns the particular section of path, but a grant of access is given via the deeds
So yes, if you wanted to put a gate across this path on your property then you could do so without permission from the neighbour, but obviously you should make it clear to them that you are not denying them access or use of the path
It does not have to be formal, you can just tell them what you are doing
