WE've just moved nito a house and it has teh above mentioned boiler which was serviced before we bought the house.
the problem is that when you run hot water into the bath you can run the tap at full as the boiler cant keep up so it takes 15 minutes to run a bath. i can only turn the tap say 15 dergrees before you start to loose warm water.
Down stairs is fine. Any ideas Cheers
