Gardtec 800 series
25 May 2011
I have the Engineer Code but have forgotten the Master Code. (Although not recommended, I should have kept a written note!) Ultimately I would like to programme new User Codes, but is there any way that I can program a new Master Code?
User codes cant be programmed in engineers, you'll need to do a code default (engineer & user)
Have a manual? in not, google it
I have the LCD User Instruction Manual but I don't know how to do a code default. It's the Master Code that I've forgotten. I have the Engineer Code. Is this something I would do in Engineers Mode?
You'll need the engineer manual
Both codes will need to be defaulted to factory set, you can reprogram once this has been done. (if your engineer code starts with a 9 then this code cannot be defaulted)
Might also be a good time to change the battery, more than 5 years old? change it :)
