DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bosch Dishwasher won't take in water
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
stewie
from United Kingdom
PostPosted: Sat May 28, 2011 5:29 pm Reply with quote
I have a Bosch Exxcel dishwasher that was showing a E24 warning light this morning, as was was my nose at the smell of the kids stale milk residue from yesterday. This is the not first time this has happened, and aclean out of the pump filter soon had the machine draining again. However it now exhibits a new and stubborn problem.
The new error code is E15 and the water supply light is on. This happens as long as the mains electricity supply is switched on, regardless of whether the "on" or "start/reset" buttons have been pressed. The supply hose is completely empty and I have disconnected it to check that there really is water supply to the hose. I was wondering if the Aquastop valve has functioned inadvertently, but if so, how do I reset it? Or indeed, are there any other microswitches that could give rise to this error code.?
Back to top
 Alert Moderators
Leccy758
from United Kingdom
Thanked: 196 times
PostPosted: Sat May 28, 2011 8:58 pm Reply with quote
Post the model and FD number from the door.
Does the drain pump come on and stay running (low humming sound etc). It should come on when you start a program then go off after a short while.
Back to top
 Alert Moderators
stewie
from United Kingdom
PostPosted: Sat May 28, 2011 9:24 pm Reply with quote
What I see on a sticker on the edge of the door is:
E-nr SM65SE02UK/01
FD 8909
the pump runs continuously, starting a few seconds after turning on mains poer. and keeps running as long as the mains power is on. None of the buttons on the front control panel have any effect. The E15 warning message appears instantly the power is switched on, as does the flashing "check water" light.
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Sun May 29, 2011 9:14 am Reply with quote
Tip the machine backwards to see if water runs off the baseplate (have some old towels ready).
Back to top
 Alert Moderators
stewie
from United Kingdom
PostPosted: Sun May 29, 2011 10:06 am Reply with quote
Tipped back to about 45 degrees. Not a drop of water
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Sun May 29, 2011 10:53 am Reply with quote
If the water supply is good, inline filters clear, & fill hose isn't kinked/twisted then yes you may have wonky aquastop. (You could also have a blocked matrix or transfer hose). Best way to check the aquastop is to hotwire it to see if it allows flow. You can do it in-situ or remove the hose. Alternatively check it has 240v supply when it should be filling. While you're at it you ought to pull the machine out, remove the LH side plate & front plate. Take a peek at the matrix and transfer hose to see if either is gunged up. Be careful, water & voltage don't mix well icon_eek.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
bosch dishwasher water check 16 420 Sun Jan 25, 2015 1:52 pm
Bosch Classixx dishwasher not drawing any water 2 1140 Fri Jan 16, 2009 9:52 pm
Bosch Dishwasher - not enough water 5 220 Sun Dec 23, 2012 6:19 pm
Bosch Dishwasher No Hot Water. Help! 5 8460 Wed Jan 12, 2005 11:09 pm
Bosch Exxcel dishwasher check water light on 2 240 Mon May 21, 2012 8:15 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
