I have a stone staircase going down into our cellar. It looks as though it is knitted into the walls. The walls are either side of the staircase and run perpendicular to the house.
It's a 2-up 2-down end of terrace with the staircase in the centre splitting the rooms. The ground to first floor staircase is wooden construction, the ground to cellar is stone construction.
I need it removing so a new more compact staircase can go in it's place to accommodate a lower floor with a cellar conversion. I am particularly worried about what structural benefits this staircase is giving to the walls...
How do you go about removing these?
The first thing that came into my head was an angle grinder with a decent disc and slice them off at the wall - leaving the knitted section embedded in the brickwork.
Thanks.
Thanks.
