Corsa 2001 remove rear bumper
15 Jun 2004
Norwich
Need to remove the rear bumper, I have to replace the reflectors that are mounted in the bumper.
I can see 4 x torx screws in the boot.
10phil, thanks for the link.
I had found that & others that all seem to vary, was hoping to get someone who had done it.
Can only find 1 nut under the wheel arch.
It was a 'c' I have done it now.
You need to get the rear wheels off, so you can get to the nuts.
I took the bumper off, on Monday, ordered the part on Ebay, it arrived yesterday, & I fitted it.
The actual light assy fits into a plastic moulding that is welded to the main bumper, both of these welds were broke.
I used a soldering iron to re-weld the parts back, also for belt & braces I used hot melt glue.
If I say so myself, I think I have done a good job, its a time consuming job with a £10 part.
