Hi all,
After my fun and games on Monday (you may have read) on trying to refill my system aftr draining down i know seem to be loosing pressure.
Since Monday tea time when i sorted the noisy pump and fan out i have lost about 1/4 bar of pressure.
Pressure bar not previously moved in 12 months prioir to Monday.
I have checked all rads and valves for dribbles of water and they all seem bone dry - no sign of damp carpets/floors.
I was undoing the auto release valve on the pump on Monday to clear air and just checked it and it wasnt done back up tight - can this be reason?
All pipe work downstairs is brand new and only 9 months old as are all 5 rads downstairs (fitted at same time)
Upstairs rads are old and use microbore but still see no sign of leakage.
Boiler pressure does not rocket out of control either when CH is on (have it on now as a test to try and move some water around and see any leaks)
Boiler is a Vaillant Turbomax Pro 24e
I read about flat diaphrams? Could this be issue? Are they easy to check?
Any advice you knowledgable folk can offer me please?
Regards
Regards
