DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fitting kingspan between rafters, how fixed?
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
Jonnabrad
from United Kingdom
PostPosted: Mon Jun 06, 2011 5:13 pm Reply with quote
Hi
About to start cutting kingspan to size and installing between rafters on a pitched mono ceiling. What is the best way to fix the insulation in place. I was thinking of screws through the rafter into the kingspan. Is this ok?
Would this be done before or after felt and batterns are fitted.
Thanks for any replies
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
PostPosted: Mon Jun 06, 2011 6:26 pm Reply with quote
Cut it so that it is a snug fit
Back to top
 Alert Moderators
Jonnabrad
from United Kingdom
PostPosted: Mon Jun 06, 2011 6:52 pm Reply with quote
Is that how it's done, cheers.
Is it worth cutting it a mil or two larger than the space and carefully forcing it in?
Jonna
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
PostPosted: Mon Jun 06, 2011 8:08 pm Reply with quote
It does not compress much, so cut it to size otherwise you have trouble getting it in.
Bear in mind that the rafters may not be parallel and might be a bit twisted.
Fill any gaps
Back to top
The following user says thank you to ^woody^ for this useful post:
Jonnabrad (6 Jun 2011)
 Alert Moderators
Jonnabrad
from United Kingdom
PostPosted: Mon Jun 06, 2011 8:54 pm Reply with quote
Cheers woody!
What would you fix the under rafter 50mm boards with, screws or roofing nails?
Jonna
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
PostPosted: Mon Jun 06, 2011 9:27 pm Reply with quote
If you are plasterboarding, then just a few screws will hold it until you put the main screws through the plasterboard
Otherwise, screws with some large "penny" washers, or get some builders band and cut that into pieces 35-50mm and screw through them
Back to top
 Alert Moderators
Jonnabrad
from United Kingdom
PostPosted: Tue Jun 07, 2011 7:24 am Reply with quote
Cheers woody, apprieciate the input!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
How to tell whether leak has been fixed successfully or not 5 740 Sun Aug 16, 2009 7:40 am
AWOL roofer and problem not fixed 4 620 Tue Mar 10, 2009 3:30 pm
Gutter Leak - Fixed...Leaking again...Fixed....Leaking again 14 22960 Tue Jun 01, 2010 9:57 am
Gutter/Roof NOT fixed...what now ? 9 480 Tue Aug 18, 2009 10:09 am
How to dismantle a down pipe that's fixed at both ends? 4 80 Tue Apr 09, 2013 5:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
