TV/Sky in 3 rooms
V1k
7 Jun 2011
Essex
Hi, I'm setting up co-ax cables in the cupboard under the stairs in my house so that I can use a co-ax switch to basically send that signal to 1 of 3 rooms.
I want this system to work with sky as well but understand that I will need to boost the signal as it goes into the cupboard.
've read something about a masthead amp - what's the difference between this and something like the following:
http://www.maplin.co.uk/4-room-sky-distribution-kit-223487
Also what are the better models of amps to buy on a budget?
Thanks.
With this set up you will have to watch the same channel on all the tv's {magic eye} is that what your after ?
As long as the ppl in the other room dont mind you switching channels then its fine .
There's only me in the hosue and so I'm fine with that, but just want to make sure that the signal is good enough as the longest co-ax is almost 25 meters long - Just want to make sure that the TV connected to that cable has a good signal reaching it?
