kitchen taps
10 Sep 2009
Norfolk
could anybody tell me where i might be able to get hold of swivel spout for mixer taps without buying the whole tap.
Only from the maker I'm afraid - and that may be a long shot......or cannibalise the spout from a new identical tap if fitting it is the issue.
If its just an 'o' ring issue, you could get around that though.
John :)
the reason i need one is the end of the spout is scaled up, and looks like somebodys been jabbing something up there so when cold water is turned on it comes out at all different angles,
Often enough the spout end can be unscrewed to sort that very problem.....however if its fixed then you could try immersing it in Viakal or some other claimed limescale remover.
If it has the gauze spray diffusers on the end you could probably cut them away to save the hassle of a new tap.
John :)
