wc fitting
28 Jun 2005
I have a wc with the waste going straight down into the floor..I am remodeling the shower room so I need to remove the wc and replace..but I cannot see how the unit connects to the waste underneath. The rear of the wc is solid and therefore I am assuming that the unit push fits onto a waste that is protruding a certain amount from the floor and that by gentley twisting, I will be able to remove the wc bowl...am I correct or am I missing something?? :(
kevplumb said:
fink he wants to know how to remove it
not fit it
specc in greece :oops: :oops: :oops:
Most regs are double Dutch, so once you know how to fit it you will know how to get it apart :oops: :oops: :oops: :oops: :oops: :oops:
greekman - as it isn't obvious(presumably!) you'll probably have to break the pan with a hammer cos its cemented in.
Not without risk of breaking the pipe which is in the ground, or filling it with bits of pan.
Noo loo will be a pushfit connection of some sort
break it well high stuff a bag down
and WEAR GLOVES the broken edges are like razor blades
ask me nicely and i'll post a pic of what broken china does to flesh :cry:
YES PLEASE Kev
brumylad said:
YES PLEASE Kev
how long did it take to heal, kev??
I wouldn't start by smashing the outlet. Would use a small grinder around the pipe and then break it off. Then you can push a rubble back down the hole to stop other debris falling down never to be seen again.
I tried using expanding foam to plug the hole before putting a layer of cement on. For some reason the foam went all gooey rather than going solid :cry:
as promised brum not the best of pics but you can see the scar
moral dont try and carry a cracked pot
that went through my jeans as well :cry: :cry: :cry:
