worcester 240 rsf h/w prob
28 Jun 2005
Manchester
my combi boiler runs fine on c/heating but no hot water turn on tap but demand light does not operate also can anyone tell me where i can download a service manual from??? :(
kevplumb thanks for the site could not find it using msn search got contact no they are sending me a manual in post dgs no flow rate is normal it just stopped heating water during a shower
I would appreciate a copy of the manual.. I can't find how to email you however...
I will happily put the PDF (if i am allowed to) on a website for anyone to download if needed...
Poss causes may be the HW flowswitch or sensors, try swaping the leads over from the HW to the CH and see if it works then....
On the 240 its usually just the diagphram in the diverter valve,the small black plunger should come out and contact the two micro switches when you open a hot tap ,you can unclip the micro swwitch box and depress the micro switches manually to tast that they work ( carfull as one is 24v but the other is 230v and both must be pressed at the same time). a kit is available to change the diagphram at about £20 and its not a dificult job
Should have gone to "Specsavers"
________________________________
lynda, moderator
Post locked, so new posters can not break forum rule 7
