Scantronic 9448
13 Jun 2011
Sussex
I have a wired scantronic 9448 alarm panel with a remote 9427 keypad.
The alarm is activated when we have a power cut even though I have a 12v battery (6 months old) within the panel, this means that I can't deactive the alarm until power is restored. What can I do to fix the problem?
Thank you for dropping in.
You'll get a better response on the alarms forum.
I've asked you to be moved.
Bye, missing you already ;)
Sounds like the battery fuse. That needs checking, but ask yourself why its blown ;)
Have you a professional battery tester?
Looking at it is not a test.
Nor is seeing 12 volts with a meter.
The reason your outside sounder rings in a power cut is the fact you have a duff battery in the panel.
Time for a new battery, want me to tell you the make and model needed?
change the abattery fuse
the battery should be ok (as you say its only 6 months old)
you will need a 1 amp 20mm (glass fuse) from maplon electronics
Oasis
Thanks for all the swift replies.
Not sure which is the battery fuse so I changed all 3 glass fuses then turned off the mains power and hey presto, it didn't trigger the alarm.
Really appreciate your kind assistance - thanks. :D
