Hi
Building regs advice needed! AGAIN
About 5 years ago we partially knocked down a load bearing wall to create kitchen diner. The solid brick wall was supporting joists above, 1 set running from each side of the house overlapping in the middle over this supporting wall. Builder assured us he was doing it to building regs and got an RSJ to bridge this gap of around 180cm. Before boxing it in he advised we should take photos for future evidence of compliance........of course we forgot and the following day we returned from work and it was boxed up!
Now i'm worried that this could affect chances of future sales/price and i feel i need to get the relevant certificates.
What is the best course of action?
i've done lots of reading ......and done nothing to comfort myself! it true what they say a little bit of knowledge is dangerous!
i believe i need a structural engineer to check what is in place is correct....can this be checked without ripping all the plaster down? and then approach BC......is this called regularisation or would it just be an inspection? not sure what the difference is other than price!
i have even pulled up some of the floor boards upstairs and found the RSJ i dont think this will satisfy the SE
My understanding is i need SE to work out what RSJ i need for load (currently 4inchs wide), RSJ needs to sit on piers with 15cm overlap on concrete padstones and then boxed in with double thickness fireproof plaster board? even if i open up certain areas can you identify all of this retrospectively?
many thanks P.s for a better look at pics they r in my albums
