Hello,
I'm looking for some advice on if I need to buy an all new Flue or not for a replacement condensing combi boiler?
I currently have a Ravenheat condensing combi which has a vertical flue already fitted (100mm dia - 2x1m extensions with an exit through the roof). The Worcester 25Si I have bought which will be replacing it looks to take an identical 100mm dia flue (if I buy a horizontal to vertical flue adapter) but could somebody please advise if I need to buy a whole new flue or can I use the existing one? as far as I can tell they are both the same construction - looks like stainless steel inner tube with a plastic outer.
I want to get all the equipment necessary ahead of getting a gas fitter in to install it all.
Thanks in advance,
John
Thanks in advance,
John
